08-10-2012 09:48 AM
I have a fairly simple question that I'm having an issue with solving.
I am looking to input a Boolean array to a sub-vi that will take that array and dictate a single boolean output to be Boolean False or Boolean True.
For instance, the array will be 1D boolean array, with a depth of 2 index values.
-If both index values are False then the sub-vi will kick out a False value.
-If both index values are True then the sub-vi will kick out a True value.
-If one index value is True then the sub-vi will kick out a True value.
Any ideas?
Thanks.
08-10-2012 09:50 AM
Somehow posted twice. Here's the original:http://forums.ni.com/t5/LabVIEW/Values-of-Boolean-Array-to-dictate-output-to-be-Boolean-False-or/td-...
