10-24-2013 09:17 AM - edited 10-24-2013 09:20 AM
Hello
I'am using LabVIEW 2013 f1, DAQmx 9.7.5, NI PCI-6229 with SC-2345
I create the Task programmatically in Labview which is shown in the attachment.
When I start the measurement the first analog input channel shows the scaled max (e.g. constant 42 -> module SCC-AI01), the other channels are correct. When I use MAX with the test panel I can measure the value correctly.
I've checked the inputs of both DAQmx VI's, they are correct.
I've tested both task configurations separately.
The TC Configuration works without problems.
The AI Configuration itself shows the same behaviour.
Is it possible that there is a bug in one of the two used DAQmx VI's?
TIA
10-24-2013 10:47 AM
Its hard to tell from a picture but I would look at the scaled min and max values in the first scale, are they reversed? also are the scale names unique?
10-25-2013 02:43 AM
As attachment you can find the VI I've created for demonstration.
In the Screenshot you can find the OUTPUT Data.
Expected Output:
AI01: 24V
AI02: not connected
TC01: room temperature
TC02: not connected
TC03: not connected
TC04: not connected
11-07-2013 09:26 AM
Hello wolfgera
I configured an Test computer with an PCI 6229 and an SC 2345 (SCC-PWR01). Tomorrow i will test your VI. Are there other specifications/settings, which i have to know?
Best Regards
Simon
11-15-2013 05:06 AM
The problem is the misinterpreting from the voltage range from the AIO1 module( +- 42V to +-8.4 Gain 0.2) which is placed on the SC 2345.
The selected I/O channel in the VI is AIO with an intern scaling back to min and max of 42V. The manual scaling in the VI set the expected Ranges to a threshold, which is too low ( 8,4 V), so that every measurement which is grater than 8,4 takes the configured max Voltage Output.
Best Regards
Simon
