07-30-2015 12:50 PM
The VIs were originally written in LV 7.1 but then compiled in LV 2009 and saved. These VIs worked fine on Windows XP machine.
Unfortunately, the XP machine was crashed and I am trying to run these VIs in LV 2010, with windows 7, 32 bit.
I have installed traditional DAQ drivers (latest version, 7.5) alongwith DAQmx (version 9.8).
We use these VI to control the vacuum valves, using PCI 6503.
To initiate we first use a VI that reset the valves and the PCI card. The name of the first vi is: portconfig.vi This vi uses port config and port write VIs. I see the error 10401 from port config vi, when I run step by step (i.e., sequence 1). However, the VI runs but not doing any actual work.
The second VI that depends on first VI, and therefore the second VI is also not working. on this VI we have buttons (representing valve) and when we click on them, the valves should shut off or open, but nothing happens in LV2010. the same VIs worked in LV2009!
PCI 6503 card is defined under devices and interfaces in MAX. It is not defined under legacy DAQ devices. When I test PCI 6503, it works.
I am attaching both the VIs (there are in QuadMain.llb). I dont know how to get the actual VI from the harddisk...
first open portconfig.vi
then open Control Panel.vi
there are global variables used in Control Panel.vi, there are listed in Valve Global.VI, which is in globals.LLB (second attachement).
I really appreciate if someone can convert these VIs for LV 2010.
Solved! Go to Solution.
07-30-2015 01:04 PM
07-30-2015 01:12 PM
I installed DAQmx because the second VI use DAQ assistant and may be other features of DAQmx. Without DAQmx the second VI did not open in LV 2010. So, as soon as I installed DAQmx, the PCI 6503 automatically removed from legacy DAQ devices and listed as just device.
07-30-2015 02:21 PM
You may check with NI support if there is an issue using DAQmx 9.8 and Traditional DAQ 7.5 on the same PC.
I remember that there were compatibility problems with some of the DAQmx/TDAQ drivers.I think it was related to DAQmx 8.8 and TDAQ 7.4, but I am not sure.
08-04-2015 09:59 AM - edited 08-04-2015 10:01 AM
In connection to my question, it is possible to set PCI 6503 as legacy DAQ device in MAX?
The attached image shows how the list of devices in MAX looks like currently. I want to define PCI 6503 under legacy device.
08-04-2015 11:21 AM
The other option is if somebody can help me to change the attached VI using DAQmx.
08-04-2015 12:12 PM
08-04-2015 01:05 PM
Thank you. I dont have to use vi with DAQmx, before running the portconfig.vi (which is in DAQ legacy). So reseting should not be a problem. It would be nice if you can tell me how to reset exactly....
thank you.
08-04-2015 02:05 PM
08-04-2015 02:14 PM
I did that. I get error 10401 from port config.
