07-12-2012 10:45 AM
Dear NI
I have embedded the VIT in labview webservice(using vi publishing tecnique not exactly but take the idea of vi publishing).
this VIT is shown on some page.
When i check in development mode the VIT successfully embed and works fine.
But when i made executeable of my application the message come on webpage that the requested vi is not loaded into memory.
please help me in this regard.
regards
07-13-2012 12:51 PM
mazhar, unfortunately I'm not familiar with VIT. If this is close to our VI publishing technique then perhaps one of this resources might give you a clue:
- How Do I Enable LabVIEW Web Server or Use Remote Panels With an Executable Built in LabVIEW?
- Publishing the Front Panel of a Stand-Alone Executable on the Web
- Web Publishing Tool using Embedded Viewing Mode and Default HTTP Port Fails to Load
- Where are good resources for developing remote front panel applications
I hope this helps
07-14-2012 04:19 AM - edited 07-14-2012 04:20 AM
thanx a lot alcava. cr i have fixed my problem and thanxs for your intrest n time. problem is due to ports reservation which is now fixed.
regards
