VISA clear: "unknown system error"
Hi!
I am using VISA to communicate with an USB DAC device. When sending standard commands like "*IDN?" everything is fine. When I clear the buffer with the VISA Clear function it response:
VISA:  (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
Actually it flushes the buffer of the device but I always the receive this problem. Do anybody have a clue what could be possible reasons for this?
(4,212 Views)
I forgot to mention that when I open the VISA Test panel in NI MAX I have no problems!
(4,209 Views)
Hi there,
Are you sure that the local variable still have the good reference and is not cleared before? Since it is working in MAX I guess the issue is to search in this direction.
Certified LabVIEW Architect (CLA)
(4,149 Views)
What was the resolution on this?  I'm having a similar issue as well.
(3,741 Views)
