11-07-2012 03:00 AM
I would like to resize the VISA resource control programmatically. However, I'm observing some unusual issues. If I want to pragmatically change the size of this control the decoration of VISA resource control resizes; however, the combo size doesn't change properly. See attached VI for source code. Run the VI and try varying the size.
This observation is observed for most of the controls placed in IO palette on front panel.
01-30-2013 05:36 AM
Hello buddy,
What property node you are using is only for area so it works fine, If you want to reesize the text then go to
property node --> Text --> Size.
In the snap shot i showed.
Let me know if it works
