VISA Discard Events Function Fails to Accept "all enabled"
The "VISA Discard Events Function" VI, according to documentation, and also its default value, should accept the "all enabled" event type. This should be a valid input because it is valid to want all events to be flushed. But when given this input the error -1073807322 is output.
(1,989 Views)
That's wierd. Sense it's the default, try running it with nothing connected to that input and see if you still get the error.
TimC
(1,964 Views)
