01-17-2013 09:50 AM
I found several topics addressing the VISA 0xBFFF0011 error. I have a single calibration instrument attached (via RS-232) to a B&B ES1A adapter on the local network. I originally wanted to use it as a COM port from a custom calibration routine. However, two computers are calibrated simultaneously and I switched the 'driver' from B&B's RealPort (Virtual COM) to using TCP sockets.
I built a test VI (as an EXE) to communicate with the instrument. I tested on my dev PC, yesterday and it worked OK. Today, I assigned a static IP to the adapter, so that it could be found by both targets on the local netwoork. I copied the EXE to a target PC (#1) and it works okay there. To test simultaneous access, I tried to run from my PC, but it returned the VISA error 0xbfff0011.
The possible reason is:
ISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
Some of the topics that matched the error:
Describes a COM port issue with local computer, 2 pages. Focused on fixing the problem via Device Manager and MAX.
Describes a TCP connection issue. Issue resolved in that the network instrument was locked up.
Describes a similar network issue. Issue was with instrument. Inquiry into instruments, etc, but not resolved.
Things I have tried:
Target PC #1: Running Test program & communicating with network instrument
Development PC:
1. ping: ok
2. in MAX, change IP addresss (when changing from DHCP to static IP): test BSOD'd the dev PC
3. in MAX, Delete Network VISA resource
4. in DevMgmt.msc;
found the device with its old IP address under Multi-Port Serial Adapters! => Uninstall it.
5. in MAX, Add Network VISA TCP/IP Resource
Manual Entry of address, port
6. MAX reports the specified IP address as its 'name' and reports actual IP address = 'Unknown' (both PC's)
7. Stop program on Target PC #1; Run test program on Dev PC => <ERROR> on Dev PC
> Restarting communication program on Target PC #1 works, still.
DEV PC: > Win 7 Pro; LV 2009 sp1; NI VISA 5.1.1; MAX 5.1
Target PC: > Win 7 Pro; LV 2009 sp1 Run-Time; NI VISA 4.6; MAX 4.6.2
01-20-2013 10:30 PM
hello Kenneth
Please check this link below, it is taking about your error code...
