03-26-2012 02:00 AM
Good afternoon, everyone. My name is Leong, and I have the problem to install the VIPM after I download the VIPM from the website. I installed the NI labview 2009 run time software, the message display as the below:
Error 5 occurred at an unidentified location
Possible reason(s):
LabVIEW: File already open
May I know that what is the problem so I know how to solve it? Thank you for your kindness help.
Solved! Go to Solution.
03-26-2012 04:08 AM
Is the error from VIPM installer, or from the LabVIEW Run-Time installer?
If from the VIPM installer, you may have more luck searching the VIPM forums: VIPM forum
Try reading this post from Jim Kring: How come I get error 5 during VIPM installation?
03-26-2012 09:57 AM
Dear Thoric. Thank you for your kindness to provide me the solution in order to overcome the problem I faced. I solved the problem according your solution given to me.
Sincerely yours,
Leong Yun Siong
03-26-2012 09:59 AM
03-26-2012 09:59 AM
Leong, you should press the "Accept as Solution" button next to Thoric's reply. Also you should press the Kudos button. That means that you like his reply.
04-02-2012 08:32 PM
Thank you, Steve. I owe you one.
