05-23-2011 12:04 PM
HI,
To be honest, although I believe I am a experienced LV user, I am not that much familiar with networking, and I couldn't find a "for dummies" guide to publishing VIs, hence the question here. I want to obviously puvlish my front panel so that it is remotely controllable. I am running the VI on a laptop, which is wirelessly connected on the internet, whereas the "index.html" file of the front panel web page is hosted on the university server.
I set the web server to be something like "C:/users/desktop/web", published an index.html file, which I then copied to the virtual drive of the university. When I load the page on a web browser though, although I can read the page, I get the message on box that the vi was supposed to be, that "The server does not support remote panels".
Clearly I am doing something wrong here, or I haven't understood something in the procedure.
Any help is appreciated!
Thank you in advance!
05-23-2011 12:16 PM
We both are in same boat, but I did pass the first hurdle, do see here and also refer to the link in that post
05-23-2011 12:28 PM
For the specific error message that you are seeing, review this document: http://digital.ni.com/public.nsf/allkb/C23EF1551D8C52ED86256B140073EE2E
As for starting material, here's one: http://zone.ni.com/devzone/cda/tut/p/id/4791
05-23-2011 12:47 PM
Thanx for the quick replies!Unfortunately, before posting this question, I had already checked these links, and still didn't manage to work out!
07-11-2011 09:01 AM
I also had big trouble getting a frontpanel to run on a cRIO 9074. The solution was to move the html-file one level up from \ni-rt\system\www to \ni-rt\system and changing the respective DocumentRoot entry in \niwebserver.conf.
Also this is a known issue (#255627), but there is no official workaround.
