07-21-2005 07:55 AM
07-21-2005 08:26 AM
It IS the merge VI function. You only need to check it, and if you select the VI from one of the palettes, its code will be merged.
You can get the option by going to Tools>>Advanced>>Edit Palette Views, adding a VI to a palette and right clicking it.
07-21-2005 08:34 AM
Thanks tst. The first time I tried it, it did not work. then I looked at the help again and figured out what I did wrong.
Thanks again for the help.
For anyone who is interested here is how I did it. Excerpt from the help file
You can merge a VI in a custom palette view so when you select the VI icon on the palette, you can place a section of code on the block diagram instead of the single VI icon.
Complete the following steps to merge a VI in a custom palette view.
07-24-2005 03:19 AM
Here are a couple of useful VIs (7.0) I placed into my structures palette which use the merge option. They help when writing quick code.
Placing VIs in locked palettes can be accomplished by renaming the "readonly.txt" file found in the Menus\palettename folder, but that is at your own risk.
07-25-2005 10:55 AM
07-25-2005 11:54 AM
