10-22-2013 03:43 PM
Developing in Windows XP using LV2010 SP1 and Vision Development Module 2011. Deploying on Windows 7 64bit computer with NI IMAQ 4.5 amd VISA 5.0 as well as the vision runtime environment.
I was getting an error that alluded to a sub vi missing. I checked "save settings for all contained items" under source file settings under build properties.
The target machine has been running a previous build of this software that a colluege made (he quit and left it with me). So I don't think this is a compatability problem. Am I missing a build setting? I have no clue what this error means.
Solved! Go to Solution.
10-22-2013 03:50 PM
Hi
Have you already see this post ?
http://digital.ni.com/public.nsf/allkb/A0DC939E3405D37E86256F40001E17D4
It seems to be similar as your problem.
R. Kaszubiak
10-23-2013 08:58 AM
Yes, I saw this. I verified each point. One possible issue was that my project was on a network drive & libraries were local. I preformed a source distribution and put the project locally on my computer. The dependencides automatically mapped in. Everything runs A-OK on the development PC. I still get the same error on the runtime PC. With default build options I get this error instead:
The error LabVIEW resource not found:
An error occured loading VI 'NI_Vision_Development_Module.lvlib:IMAQ Set Calibration Info'
LabVIEW load error code 3: could not load front panel
Am I missing some option to pack all of the dependencies up?
10-23-2013 10:13 AM
The problem seems to come from the runtime because of all is OK on the local computer which has all software installed in local.
There is two possible solutions :
- a runtime problem :
If you use the NI Vision Development Module, you must have the NI VISION Runtime that you must pay.
- a camera promblem :
I you use a National Instruments camera, the runtime is integrated in the drivers and it is free but if it is not a NI camera, sometimes you have to paid Runtime IEE 1394 license.
R. Kaszubiak
10-23-2013 10:34 AM
The runtime computer had rev 2010SP1 while the development PC had rev 2011 of the vision runtime software. I updated the runtime PC and that solved the problem. Thanks!
10-23-2013 10:44 AM
It is a good thing.
I am happy that your problem is solved.
Best regards.
R. Kaszubiak
