01-27-2009 11:11 PM
Respected Sir/Mam,
I have created a Vi for measuring the signal during modal analysis. The Vi is giving a very good signal but the problem is in writing the data. The no of samples is given as 10K and rate is 100k but it writes only 5k datas in the file. The signals are good but the data logging is the problem. I have attached the VI. Your earliest reply will be very much helpfull to carry out my further work.
thanking you
ram
Solved! Go to Solution.
01-28-2009 09:42 PM - edited 01-28-2009 09:42 PM
Actually, there's nothing wrong. You are collecting 10k of time-domain data. The spectral analysis you are performing is transforming this into 5k of frequency-domain data. It looks like everything is as it should be.
Mike...
02-09-2009 11:38 PM
01-10-2014 11:37 PM
I need help for selecting a noise filter to eliminate noise while performing modal analysis. I'm performing modal analysis for a PCB board with solder balls and a chip mounted in fixture.. Please reply me for the neccessary things to be read regarding noise filters.
Thank You.
