01-09-2014 04:09 AM
Hello everybody, I not really understand why I need to use the SubVI IMAQ GetImagePixelPtr VI?
01-09-2014 04:25 AM
The VI that acquires an image from your camera just allows to copy the pixel data of an image. If you want to have the pixel values in an IMAQ image, the recommended way to do it is by using IMAQ GetImagePixelPtr. Your code looks very close to the example implementation given here.
01-09-2014 04:33 AM
Add Andrei, where I can find the Dll Labview Move Block?
01-09-2014 04:46 AM
Look here. There's also a VI snippet in it that you can use: Just drag the PNG on a block diagram.
01-09-2014 04:49 AM
Hello Günther, the example which you send me, there is a "Knoten zum Aufruf externer Bibliotheken" Copy C image to labview image -> where I can find this?
01-09-2014 04:51 AM
thank you. I will try this.
01-09-2014 05:07 AM
Hello Beatrice. Open a block diagram. Press <Ctrl-Space> which will open "Quick Drop". Start typing "Knoten ..." and hope that the node appears in your german instance of LabVIEW. As soon as it appears press Enter to select it. Place it somewhere on the block diagram.
01-09-2014 06:20 AM
Hello Andrey, I tried it like you. But now I don´t see a picture. But maybe the problem could be, that the size of the x-axis and the y-axis is different?
01-09-2014 10:10 AM
Hello altenbach, the loop rate is the number of the captured pictures minus 1.
That answer does not make any sense. What are the units? A rate is typically given in Hz. (e.g. "pictures per second" or similar).
01-09-2014 03:26 PM
Hello Beatrice.
Your code has at least two issues:
(1) You must specify "Map Pixel Pointer" when calling "IMAQ GetImagePixelPtr" before running the Call Library Function Node that calls "LabVIEW:MoveBlock". To my opinion Andrey forgot an "Unmap Pixel Pointer" after the "MoveBlock" (but I didn't check this for memory consumption issues).
(2) MoveBlock takes three parameters in the order source, dest, size. You have wired the pixel pointer as parameter#1 and the image array as parameter#2. Your image array must be wired as parameter#1 and the pixel pointer as parameter#2.
How could this work without a crash in LabVIEW?
