VI Compile Error when I try to run VI
I used an mxDAQ example for outputting and analog voltage as my base program.  I normally need to use a rather complex equation for my waveform and this works fine.  However, I am trying to create a trigger at each maximum of my signal.  To do this I tried adding a block that compares the current waveform value to the max value.  When the two are equal it is sent to a case structue which will generate a signal.  However, when I tried to execute the VI I get a VI compile error (no numbers or anything else to describe the error).   At least on my machine it no longer recalls the default values that I had set.  I am very new to lab view and I can't seem to find much information which will help me pinpoint why it can't compile.  I have attached the library where I have the original VI (Generate Voltage) and the new VI which won't run (voltage2).  Any input would be appreciated.
(1,871 Views)
Hi Jack,
seems like a "too many ExpressVIs"-error Smiley Wink
Try to get rid of them...
(1,860 Views)
