04-18-2014 02:20 PM
Has anyone tried to run a LabVIEW real time system communicating over a wireless network instead of wired Ethernet? Thanks.
04-21-2014 09:58 PM
You've got the myRIO... running Linux RT and has built in wireless (802.11 b, g, n).
http://www.ni.com/pdf/manuals/376047a.pdf
Otherwise, I haven't done it personally but I think most others will connect a wireless router to their cRIO primary port and connect to a wireless netwoark that way.
04-22-2014 03:19 PM
Hi Tim,
Thanks for the reply. I was actually hoping to do this with a PXI system. Is there any supporting hardware for that? Thanks.
04-22-2014 03:23 PM
I would think that all you need to do is hook it up to a wireless access point and the system - whatever it is - wouldn't even know it was hooked up wirelessly...
