04-10-2015 12:25 PM
That picture is the contents of the VI. I do a line feed just to see the error on the serial port monitor (Error - Unknown command: '~.'). Again if I enter "~." in tera term the DUT exits the menu as expected.
No error on output of VISA write
04-10-2015 12:44 PM
Any chance you can provide a link to documentation for your device? What are you using for a serial port monitor?
04-10-2015 12:48 PM
I'm just using a homemade cable(rx only) with tera term to monitor serial port activity. i don't have documentation on the device.
04-10-2015 01:31 PM
04-10-2015 01:41 PM
Dennis,
I attached a snippit of tera term.
04-10-2015 01:46 PM
04-10-2015 03:17 PM
Perhaps you could turn your setup around. Let LabVIEW (which won't do any translation) do the serial monitoring, and do the communication with TeraTerm. Send ~. from TeraTerm. Do a read in LabVIEW. See what bytes actually get sent.
04-13-2015 08:13 AM
Dennis/Nathand,
Thank you for your feedback. I've attached a snippit of me entering ~. on the serial port and reading it back in labview. Labview appears to be reading back ~.
I'm also searching to see if ~ is interpreted as some other character in tera term but no luck so far.
04-13-2015 08:26 AM
04-13-2015 10:21 AM
Dennis and all,
Thank you.
Mike
