Using table data to change numerical control values over time
In my labview programme, I am looking to change a numeric control's value over different time changes instead of manually changing the values which running the system.
e.g.
numerical value = 5    hold for 5 second
numerical value = 7.2 hold for 2 seconds
numerical value = 15 hold for 1.5 seconds
This list can be long, and I want to input it into a table in Labview and have the 2 columns (numerical value and time duration) to be linked to two numeric controls on the programme. The commands will run in a sequence, so once the time duration of the first row is finished, it will move on to the second row and change the value to 7.2 for another 2 seconds and so on.
Is there anyway to connect a table to numeric controls? And then later change the data in the table to run a different sequence.
Thanks for your help.
(2,917 Views)
Hi LRUCL,
Your VI will not run "in a sequence", but it will run in a LOOP! (And you should not use a table, but an array…)
And if you combine this with the elementary autoindexing feature of LabVIEW's loops your task will be more than easy!
(2,910 Views)
If you want it to be a set sequence, why would you ever make it a control?  A control can be changed while the program is running.  This seems contrary to what you want.  Change your logic to use a constant instead of the control.
(2,861 Views)
GerdW wrote:  (And you should not use a table, but an array…)
A table is just a 2D array of strings.  A simple FOR loop with autoindexing should do the trick quite easily.
GCentral
(2,825 Views)
