08-22-2011 04:19 PM
what makes the visa commands better? Im not trying to be a smart ass i just really dont know.
08-22-2011 04:26 PM
08-22-2011 04:34 PM
ok so im reading about index array but i am just not getting how to use it.
08-22-2011 04:44 PM
08-22-2011 05:33 PM
so i understand that part but how do get the strings to where i can use them as a control? i can the data to display in an array but its stuck as an indicator how do i convert to being usable.
08-23-2011 02:00 AM - edited 08-23-2011 02:06 AM
Hi Tod,
you only display the data in an indicator, but you can use the data also for setting up device communication. No need for a control here...
Maybe you should explain "usable". Do you want to change the values read from the file before using them? I thought you would use them "as read"?
IMHO the values from the file are instantly usable:
08-23-2011 03:37 PM
ok so i think i understand the picture you posted and i have my program working. But what im wondering is if there is a way to put the data im indexing out of the spreadsheet file into a text box for later use. Also is there a way to index the array i have created. Right now its setup as an indicator and i do not see an option to where is can be use as both an input and an output, Im trying to eliminate the need to keep accessing the file.
08-23-2011 04:33 PM
You can create a local variable of a control to be able to write to it, and a local variable of an indicator to be able to read from it.
It seems like you are missing some basic LabVIEW concepts. I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
08-24-2011 01:18 AM
12-05-2013 08:52 AM
Hello everyone!
I m posting here cause I think that my problem is relative with the subject.
I m taking some data from my instrument so I can graph them.The data are in form 34.123 , 25.845 , 41.298,etc
I m using spreadsheet string to array with "," as delimeter and "%f" as a format string but the array that I get is like this 34 25 41.
Where is my fault and I don't get all the digits?
