03-16-2008 01:54 PM
03-20-2008 11:54 PM
04-06-2008 02:27 AM
if wiimote.dot1vis then
endif
for each of the elements you want to enable, then Labview might have access to it.
I'm ecstatic about this. I overcame the Microsoft BTStack barrier! I just did it tonight (erm, or this morning) and so I still need to play around with it just to make sure. Maybe I'm dreaming. I haven't been so lucky in a long time.
04-09-2008 12:50 PM
Hi all,
Is there a 'Master VI' that should be run or are these merely sub-VI's that
should be wired up? I currently have the Wii linked up and am looking to
gather, initially at least, some accelerometer data and write the data to file. Thanks!
04-11-2008 01:02 AM
04-22-2008 04:34 PM
05-07-2008 02:35 AM
Hi I'm a very new user to Labview, currently having alot of problems messing with the VIs. Does anyone have a working sample on using the Wiimote to remotely control the lego tribot where I can just compile and load it into the NXT?
Help is very much appreciated, thanks! 🙂
05-08-2008 02:47 PM
06-01-2008 10:35 AM
Dear sshearman
I have used your program WiiimoteLib121test (events).vi,It can work (with the blusoleil)
could your tell me
How could I send the X Acceleration data to a new Indicator(not to the wiimotestate.ctl)
because i want to send the data to the 8051 microchip
Could you give me a example to do that
The Attached file is my vi file changed from your WiiimoteLib121test (events).vi
But the X Acceleration data could not changed repeatly
Thanks for your help
06-02-2008 11:05 AM
