02-02-2007 03:14 PM
I am Using USB 6008 with LV 7.1. The application is voltage logger and i would like to use excel and upload the data . The Columns will be the channels and the rows will be the data.
The data comes from the DAQmx vi not like a simple string or an number it is kind of cluster data
which contains strings and numbers and more for each measurement.
I tryed to work with spraedshit and it goes ok but it is not conveniant to convert later to excel.
Do you have a solution for that please?
(How to extract the data from the cluster type format that is used with USB6008).
TX arik
02-02-2007 03:20 PM
Sorry , i attached wrong file
Here is the problematic file attached now |
02-06-2007 09:02 AM
02-06-2007 10:15 PM
TX
I will examine that soon and return back
Have a nice day
02-06-2007 10:53 PM
TX TX TX
I understood my mistake , it is a great solution - DAqmx has all kinds of output formats
I found what i need and i have seen your example.
Great , solved
TX |
02-08-2007 06:01 PM
