03-11-2009 10:35 AM
I have labview 8.5 version in my Winxp. I have PCO camera (pixelfly). So far I know that it saves 12 bit images. I used normal save pattern of labviewas png,tiff or jpeg. As .pngit saves the images as 32 bit and as bmp it takes 8 bit images. But the picture quality is not good. I used IMAQ to take single picture and to save it I used IMAQ Write File 2. I used the following mechanism.
1) IMAQ ImageTo Array--> To unsigned word integer--->IMAQ ArrayToImage--->IMAQ Write File 2---> save it as .png file.
Please inform where I made the problem. Why the picture is not as like as 12 bit images of PCO Camera.
Stuttgart University,Germany.
03-11-2009 11:30 AM
Hi there
you need to use a picture format capable of at least 12 bit color coding, e.g. .tiff. Maybe IMAQ supports tiff, or search for "tiff" in this forum.
03-12-2009 07:40 AM
03-12-2009 08:22 AM
IMAQ Create.vi supports Grayscale(I16) and RGB (U64). Both should be suitable for 12Bit Greyscale.
Documentation of "IMAG Write File 2.vi" says:
IMAQ Write TIFF File 2
Writes an image to a file in TIFF format.
Note 16-bit monochrome images and 64-bit RGB images are nonstandard extensions of the TIFF standard. Most third-party applications cannot read 16-bit monochrome or 64-bit RGB TIFF files. For compatibility with most applications, write 16-bit monochrome images or 64-bit RGB images into PNG files. |
03-12-2009 09:40 AM
11-10-2015 11:49 PM
I have some problems with IMAQ initialization with PCO camera. Can anyone suggest any driver need to be installed as it is saying initialization failed and could not detect any active devices. Besides, I have no problem with my other VI's provided by company which use internal memory of the camera to save images.
