06-12-2014 08:14 AM
Hey there, I have a table of x values which I have made into a wave form.
I was curious as to whether this wave form could be outputted by my Ni Daq via Daq assistant, or is there an alternative method for outputting a table of values via a daq card?
Thank you
Solved! Go to Solution.
06-12-2014 08:36 AM
Okay, I've more found the problem to be that I can't get the daq assistant to show options like it is here
http://forums.ni.com/ni/attachments/ni/170/502252/1/blockdia.jpg
Anyone have any suggestions please?
06-12-2014 08:45 AM
06-12-2014 09:12 AM
Okay, two separate questions then, sorry
How do I get a series of x values made into an output for the daq
The second question is how did this person get all the options for the daq assistant/the daq output?
That's what I have, and I'm unsure how to put wire inputs into it
06-12-2014 09:19 AM
06-12-2014 09:26 AM
Sorry about the image, just wanted to show my set up (I'm very my a newbie to labview)
Is there anyway to configure or uncorrupt the daq assistant?
I have a column for the time and a column for the displacement
Thank you for this help by the way
06-12-2014 09:49 AM
06-12-2014 09:52 AM
Thank you
06-12-2014 09:57 AM
Works perfectly. Thank you very much for your help
