10-16-2008 12:52 PM
I currently use LabView as a rapid prototyping tool for data analysis routines and plotting of results (As well as hardware control). I currently build and distribute these tools for use with the run-time engine on Windows PCs however I now need to build varsions of the same tools to run on a server under Linux.
I have already seen that this can be done using a Linux version of LabView, opening the VI and rebuilding the application. Is there a tool I can use on my current system to build for distribution to Linux systems or at least a cheaper option than purchasing an additional copy of LabView + application builder?
Cheers
10-16-2008 01:03 PM
The only tool that exists to create Linux version is the LabVIEW for Linux development system and application builder.
If you don't want to buy it and you have only a couple of apps to create, you could probably pay an Alliance member or other consultant to do it.
10-16-2008 01:11 PM
10-16-2008 01:17 PM
Thanks for swift response
As I feared then.
Unfortunately the nature of "rapid prototyping" is that it's more than just a couple of apps.
Guess I'll have to weigh up to costs of Linux version vs recoding.
10-16-2008 02:34 PM
10-17-2008 07:10 AM
