10-16-2012 04:15 AM
I'm trying to use Labview with NI Veristand, when I follow the white paper here:
http://www.ni.com/white-paper/11135/en
I do not see the same menu as detailed in step 4 (NI veristand is not listed in the menu - see attachment). I have NI Veristand installed on my computer.
Do I need to install an additional add-on?
Solved! Go to Solution.
10-16-2012 04:31 AM - edited 10-16-2012 04:32 AM
Is your VeriStand version newer than the LabVIEW version?
It could be some versioning discrepancies, perhaps?
Try putting the VI's in a project.
Br,
/Roger
10-16-2012 04:49 AM
I'm running Labview 2011 SP1 & Veristand 2011 SP1.
10-16-2012 05:09 AM
In what order did you do the install?
Installing VeriStand before LV could be a problem.
I got the same version(s) of VS and LV that you got, and that menu alternative is avaliable for me.
Br,
/Roger
10-16-2012 05:11 AM
Thanks Roger - I installed Veristand and then Labview, this could be my problem I will try and uninstall / reinstall in a different order.
