11-03-2014 10:29 AM - edited 11-03-2014 10:40 AM
I had an interesting use case today where the answer wasn't in the knowledge base, so I thought I should share.
I wanted to import a local domain using the Security Tools and Domain Account Manager on a machine the had the runtime engine but not LabVIEW intself. I wanted to do this to use different access levels depending on a user login and the group that they belong to. This is a control system computer, not a development computer. Another detail is that I use a custom runtime menu in my control system.
Normally you access the Domain Account Manager via Tools>Security.Domain Account Manager...
Then you can log in to the Domain and import a new domain.
In order gain access to the Domain Account Manager you simply need to build an EXE with the default LabVIEW menu. I made a while loop with an event structure and a stop button that fired the event structure and stopped the while loop. Run the EXE and you get a reduce menu, but you get Tools>Security>Domain Account Manger...
You can now log in and import the desired local domain.
Casey
Phoenix, LLC
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
11-03-2014 03:21 PM
Thanks for the info. I was curious about this myself as i was looking into using the DSC module and i wasn't sure how you manage access outside of developer computers.
