Using Concatenated Strings in Case Structure
Hi everyone,
I am brand new to LabView. Right now I am just trying to build a program that graphs different waves (such as sine or square) with or without different types of noise. I concatenated two strings and then have that input into a case structure. Nothing graphs when have the two options concatenated, but it does work when it's just the different types of waves being chosen. I think it might have to do with how I'm titling the each of the case structure options, but I'm not sure. Any help or suggestions is greatly appreciated.
(3,057 Views)
"Concatenation" of strings means "Take two strings and make a single string with the characters of the second following after the characters of the first".  So concatenating "Sine" and "White" will give you "SineWhite".  If your case has (as yours does) "Sine", "White", then a string of either "Sine" or "White", but not "SineWhite", will satisfy it.
(3,044 Views)
Oh ok. That makes sense. Thank you!
Do you know if there is any way to make the loop execute like:
if sine && white
  this graph
else if sine && no noise
  other graph
else...
(3,037 Views)
Accepted by topic author lvgerns
I would use a sequence of case structures. Take it step by step. Use enums for better readability.
(3,027 Views)
Thank you! I got everything to work from there.
(3,021 Views)
