NI Home
Cart Cart | Help
You are here:
Reply
Member
Placebo
Accepted Solution
Using COM 2 twice !
I have a vi which successfully communicates with COM 2, and another vi which also successfully communicates with COM 2. I would like to run them both at the same time.
Can anyone tell me the best way to go about this please ?
Active Participant Gak
Active Participant
Gak
Re: Using COM 2 twice !
[ Edited ]
Why don't you make one vi which will communicate with COM2...and send/receive data to the two vis ?:smileyhappy:
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Active Participant
josborne
In general, I try to avoid simultaneously accessing the same hardware, but I understand it is possible:
http://digital.ni.com/public.nsf/allkb/6210E70E87FE4509862573A600697EBF
Member
Placebo
This is perfect, thank you
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
