04-21-2011 01:03 PM
Is there any use for using LabVIEW merge if your software team does not to parallel development? We are starting to setup Perforce for source control, and I was considering setting up LVMerge.exe to work with Perforce. However, since we have no parallel development, I don't see any point to this. Is there a reason that I'm overlooking to setup and use LVMerge when there is no parallel development?
Thanks!
04-22-2011 04:25 PM
Hi zenthoef,
You can configure a third-party source code control provider to use LVMerge.exe as the default merge application. Here is a link that will help you configure this! Hope this helps!
Configuring Source Control with LVMerge.exe
04-22-2011 04:26 PM
Maybe I wasn't clear. I know how to configure it, but is there any need to configure it if we have no parallel development?
04-22-2011 04:47 PM
Consider a single developer making multiple changes. Merge is just not for different users. I've had to do a quick patch to fix a bug in source while at the same time, do more extended edits on the same source for new release with additional features.
04-22-2011 05:07 PM
Now that I think about it, I was confused how a single user would use LVMerge, because I don't really understand some of the differences between the arguments LVMerge uses. What is the difference between the Base VI and Your VI? According to the LabVIEW help, the Base VI is "Absolute path to a copy of the VI from where you checked it out (Base VI)," and Your VI is "Absolute path to the VI you edited (Your VI)." Those seem like the same things to me. Isn't the VI I checked out the one that I am editing? Could someone clear that one up for me?
Also, I am confused about Their VI, which according to the LabVIEW help is, "Absolute path to a copy of the latest revision of the VI in source control (Their VI)." MY source control is on a server. Do I use the server absolute path, like \\SERVER\SourceControl\Project\VI.vi to tell LVMerge where to get that VI?
04-22-2011 05:41 PM - edited 04-22-2011 05:48 PM
Base VI = unmodified version of the VI when you last checked it out
Your VI = your modified version of the same VI
Their VI = current version of the same VI on the server
If you're the only developer, Their VI = Base VI (since nobody else changes the server version). But if there are multiple developers somebody might have committed the VI since you last checked it out from the server.
06-04-2012 03:29 PM
Kind of off-topic, but still dealing with LVMerge:
LVMerge launched with Auto-Merge turned On by default. Is there any way to launch it with Auto-Merge turned Off by default? It appears that if I unchecked Auto-Merge after LVMerge launches, LVMerge still can't find changes even after it re-merges.
Doug
06-05-2012 06:55 PM
Hi Doug,
I don’t see why you are having this problem.
Maybe you can take a look at this step by step to see if you are missing any detail.
06-06-2012 07:37 AM
Sorry, I wasn't clear in my application. I'm using Subversion with TortoiseSVN. I have TSVN set up to launch LVMerge when I'm editing conflicts. The command line I'm using is:
C:\Program Files\National Instruments\Shared\LabVIEW Merge\LVMerge.exe %base %theirs %mine %merged
Everything works fine, except I'd like TSVN to launch LVMerge with Auto-resolve Off rather than On (the default). Is there a command line switch I can add to the above command line to turn it off?
Doug
06-08-2012 01:22 AM
Hi Doug,
I'm not sure if there is a command or setting for that. Maybe one of these documents can help?
http://www.ni.com/white-paper/4114/en
https://decibel.ni.com/content/docs/DOC-2936
Best,
