Use listbox to select multiple channels and display on the graph
In the first picture since  I attached (PIC 1)  shows how it does not give me option for channel (row) or column.
But when I have ring menu it gives me option for row and column.
Message 11 of 13
(1,508 Views)
Accepted by topic author studentgirl
You are not following what I showed you. You need to disable indexing on the 2D array. As it is now, you are sending in a 1D array to the "Index Array" function, so of course you do not see row and column indices.
Message 12 of 13
(1,505 Views)
That was the problem. The index was not disabled. Thank you so much gregory. I appreciate it.
Message 13 of 13
(1,499 Views)
