09-17-2012 01:16 AM
Is anyone that uses the Wii Balance Board vi's able to save & post it for compatibility with Labview 8.2 for me?
Cheers
09-17-2012 09:29 AM - edited 09-17-2012 09:30 AM
I convert to Labview 8.2 from Labview 8.6.1 version, but compatibility errors have appeared with the add function and others.I can't do anymore, because 8.2 it's and old version and i haven't.
good luck
09-23-2012 06:18 PM
Thanks so much!
10-01-2012 01:39 PM
First thank you soooo much to share these valuable information!
On question, has anybody checked what is the maximum (stable) sampling rate that this system can provide for continuous measurement. I need to record some EEG kind of signal and I need to have fixe interval between measurement from the WII board.
Thnaks,
Olivier
01-31-2013 02:56 PM
I am new to LabView but would like to use it to read the strain gauge outputs from the Wii Balance Board. When running the "WiiBalanceBoard_Get_Sensors.vi" I get an error. Both "error in" and "error out" read "code: -1" and "source: Wiimote Set Output Report.vi:13". Can anyone tell what my problem might be? Or what other pertinent details I can provide?
I am running:
Labview 12.0 (32-bit)
Windows 7 (64-bit)
MediaLink USB Bluetooth module (supported within Windows 7 64-bit)
04-10-2013 12:23 AM
I have some question about these LabVIEW code. Please help me for some suggestion.
I used these code to operate wii remote and wii balance board to collected the data, when I use the LabVIEW code with only one device ( wii remote or wii balance board ) the data really good and clear, but when I try to used both device together the data is slow down more than normally ( speed of graph decreasing to around half of normally (from my sense)).
I need some suggestion for use these LabVIEW code for get the data of 2 device together with normal speed or please suggest me about the code that I have to change or add.
04-22-2013 07:58 PM
Hi, my name is Emilio
I am trying to use the Wii Balance Board. When running the Usage_WiiBalanceBoard.vi I get an error. "The library selected is not valid for the current platform, For example you are running 64-bit LabView and the library might be a 32-bit library"
I am running:
Labview 12.0 (64-bit)
Windows 7 (64-bit)
Internall Bluetooth Dell Latitude
I need help. Thank you.
Iwould like to use it to read the strain gauge outputs from the Wii Balance Board. When running the "WiiBalanceBoard_Get_Sensors.vi" I get an error. Both "error in" and "error out" read "code: -1" and "source: Wiimote Set Output Report.vi:13". Can anyone tell what my problem might be? Or what other pertinent details I can provide?
I am running:
Windows 7 (64-bit)
04-23-2013 05:27 AM
Sorry, but the wiimote.dll library used is for 32 bits systems.
03-08-2014 02:58 PM
Hi henry,
may u pls tell me how u make it work finally?
my balance board is paired with PC and the LED is solid blue, but it does not send any data.
im using Win7 and i have tried both dongle and motherboard bluetooth devices.
03-13-2014 05:20 PM
I've been able to acquire from multiple WiiBoards on my 64bit Windows7 laptop running 32bit 2011 LabView using the WiimoteLib.dll. My order of operations are:
- Clear my bluetooth device list of existing WiiMote connections
- Pair the each board to the onboard bluetooth adapter
- Run the VI
Seems to work just fine for me. For whatever reason, I have to re-pair the boards each time they break connection with the computer (either the computer shut down or I turn the boards off). I've attached a VI that I first used to read multiple boards and it should work fine for a single board.
Let me know if you have questions.
cheers,
-will
