04-09-2014 01:41 PM
Hi everyone,
I try to change the PWM output of this VI attached to AO. But I can not get anything from the AO1or AO0 port of Myrio.
04-10-2014 10:51 AM
Hello CZ_Kevin
I opened the configuration of your PWM express VI however I did not see any channel selected. Could you attach your project?
Some basic steps to check:
- Which terminal are you connecting?
- Have you tried selecting a constant Duty cycle for testing?
- Is your loop running fine?
- Is there any error in the deployment process?
Please check these details first and if you are not able to find the problem you could attach your project so I could try to reproduce the issue.
Regards
Frank
04-15-2014 01:50 PM
Here is the project attaced. I checked what you told you everything works fine. BTW how could I change it to multiple channles?
