Steven,
I am trying to use DIO Port Config, Port Write and Port Read VIs from zadvd.lld. I am not sure whether the lsb was built on this platform, but I know for a fact that those VIs run under 5.0.1 but not under 7.1 (if my understanding is correct, that means that the lsb was built under this platform. I might be wrong). On the other hand 5.0.1 runs under Mac OS 9, while 7.1 runs under OS X.
Do you know if the files it is looking for (DIGPRTCF.lsb, DIGPRTRD.lsb and DIGPRTWT.lsb) are shipped with the standard VIs?
Thanks for the help,
Igor
