Updating a "3D curve" global variable
I'm using a "3D curve" globla variable. I can't find the way to properly update the plots of that variable ? On my main VI the 3D curve works fine but the global variable doesn't update.
(2,010 Views)
Salut Tartanpion !
May be you could post an example/ sample of your vi. Otherwise I'm afraid nobody will be able to help you...
CC
Chilly Charly    (aka CC)
         E-List Master - Kudos glutton - Press the yellow button on the left...
(2,010 Views)
