05-24-2013 10:09 AM
05-30-2013 05:21 PM
Hi Steve,
Sorry for the delay in response. I have brought this to the attention of our R&D department and they are currently reviewing the XML file that is not working. My hope is to get some more information out to you shortly and will reply here when I hear anything.
05-30-2013 06:44 PM
Thanks for the update. As I mentioned (implied?), the XML file is the least of my worries. There was a basic state machine error in bringing the slave up that I would guess is independent of any XML specification (although I could be wrong).
Steve
05-31-2013 09:25 AM
05-31-2013 10:02 AM
Tough to say - once I import an ESI XML file it seems to not be forgotten; if I delete my EtherCAT slave and then add it again I don't seem have to re-import my ESI. Is there a way to purge the ESI import from my Labview installation? (it doesn't seem to be on a per-project basis).
Steve
06-03-2013 12:59 PM
Hi Steve,
The XML files are pulled from the following directory:
C:\Program Files (x86)\National Instruments\Shared\IndComECAT\DD
This directory may not have the (x86) if you are on a 32 bit machine. Deleting the XML will make it not show up after LabVIEW is restarted. We also took a look at your XML file and noticed there were some locked operating modes in the XML file so we unlocked them in the XML linked to this post. Try this XML out and see if you have better luck.
