05-25-2011 07:26 PM
I just updated a system running Windows 7 to 64 bit LV2010 Pro. The links to the Database connectivity toolkit no longer work. I downloaded a new eval version from NI but it keeps telling me I have to be running 32 bit. I can't find a 64 bit version. Is there one?
05-26-2011 12:54 PM
Hi old_man,
There is currently no 64 bit version of the Database Connectivity Toolkit. However you can install LabVIEW 32 bit on your 64 bit Windows OS and install the Database Connectivity Toolkit to that. You can also keep LabVIEW 64 bit installed on the same machine. Your Serial Number will active both the 32bit and 64bit versions of LabVIEW.
<Brian A | Applications Engineering | National Instruments>
05-26-2011 04:48 PM
Is there a plan to release a 64 bit version?
05-27-2011 02:51 PM
I am not on the development team for the Database Connectivity Toolkit so I cannot really comment on their plans. However since 64 bit OS are starting to become more mainstream I would be expect that more and more of the modules and toolkits will be released with a 64bit version in the future.
Is their a particular reason that you require using 64 bit LabVIEW w/ the Data Connectivity Toolkit instead of 32 bit?
02-03-2012 01:06 PM
Is this still unsupported? We are porting our LabVIEW 32 bit application to 64 bit. We can leave out database support for now, but we would really like to get it in shortly if possible.
02-06-2012 01:10 PM
Hi Thomas,
The 2011 Database Toolkit is not supported with LabVIEW x64. You can view the LabVIEW Requirements in the readme for the Database Toolkit under System Requirements.
Cheers,
05-16-2014 09:38 AM
Database Toolkit Is this still unsupported?
Bests
05-16-2014 10:09 AM
We actually managed to get it working. We're using LabVIEW 2012 (and probably the 2012 version of the toolkit?). I'm not sure if we had to do some recompliation or relinking on the datbase VI's as I didn't do that part of the port. Anyway, the 64 bit version of our software is storing to Access and MS SQL databases just fine.
05-19-2014 10:11 AM
Hey Cemach,
The LabVIEW 2013 Database Connectivity Toolkit is still not officially supported with 64 bit LabVIEW. Please see the Database Connectivity Toolkit Readme linked below for more information:
LabVIEW 2013 Database Connectivity Toolkit Readme: http://digital.ni.com/public.nsf/allkb/8126595802A1B62986257B79000D69AF#requirements.
Myriam D.
05-19-2014 04:49 PM - edited 05-19-2014 04:49 PM
For a full up to date list of which toolkits are supported on different bitnesses (and which versions started supporting them), take a look at this white paper - National Instruments Product Compatibility for Microsoft Windows 7
There is a similar page for Windows 8.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
