Update from a Reference
I have a Heisenbug (a bug that disappears when you look closely at it).
I use a text control user input. Somewhere else in the program I use a reference to the control get the value. When I use it in a loop, I cannot get the Value property to populate a text indicator. When I put a debug probe on it it works fine.
I am guessing that it has something to do with the logic that updates Windows widgets. The code that updates the debug probe also forces the correct behavior in the program. How can I force this update to occur without the debug probe?
Brian Rose
(2,138 Views)
Accepted by topic author Mister_Rose
I found that if I used the Text.Text property, it worked as expected. I am guessing that the Value property does not get updated until the input is finished (Enter key or when the focus is changed).
Brian Rose
(2,111 Views)
I don't see a problem - it works just as I would expect (LV 2010, Win Vista).
Perhaps your expectations are not correct.
That is normal behavior, and usually what you want.  If you want to update the value while typing, then set the UPDATE VALUE WHILE TYPING property of the control.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(2,105 Views)
