Uninstall NI Logos or change the UDP port it is using
I have been working on application which uses UDP port number 5000. There is a conflict with lkcitdl.exe which uses the same port. It is not easy to change the port number that the application is using. I would like to know if there is an option to uninstall NI Logos (lkcitdl.exe is a part of Logos) or not install it at all in the first place.
I would ideally wish to uninstall it completely. At the least, is there an option to change the port number by these NI services?
Sudharsan
Soliton Technologies
(3,128 Views)
Yes, it is possible to uninstall the logo.
Please do following:
  1. Click the Windows Start Button. In Windows 8, look for Control Panel.
  2. Click Control Panel.
  3. Click Uninstall a program.
  4. Look for National Instruments Logos in the list of available programs.
  5. Click Uninstall.
For more information, please visit the following site:
How to uninstall National Instruments Logo
https://file.info/windows/lkcitdl_exe.html
If my suggestions helped to solve your problem, please mark this problem as solved, so that other users with the same problem could find a solution quicker.
Kind Regards,
James.
Greetings and Regards,
James
(3,036 Views)
In Control panel, you could uninstall NI Softwares installed on your PC. But not NI Logos. NI Logos is not a standalone software. So the solution you had suggested will not work.
Sudharsan
(3,032 Views)
Accepted by topic author Sudharsan62
I have a found a solution to change the port number allocated to these NI services. We could make a registry entry to specify the port range allocated for NI Logos services.
Refer this for more details - http://digital.ni.com/public.nsf/allkb/F852A8CFA4A8CABE862571C00068EF7C
http://forums.ni.com/t5/LabVIEW/How-do-you-change-TCP-IP-ports-used-by-LabView/td-p/792158
Sudharsan
(3,031 Views)
Also possible to modify Logos Ports:
HKLM\Software\National Instruments\Logos\Ports
HKLM\Software\Wow6432Node\National Instruments\Logos\Ports
(be aware that 64-bit Windows maintains separate entries for 64-bit and 32-bit processes)
In Ports:
FirstClientPort REG_DWORD 7000 (dez)
FirstServerPort REG_DWORD 8000 (dez)
This was useful for me because I wanted to install Sentinel Protection driver and could not because of this problem.
After modifying in registry and restart, it worked!
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(269 Views)
