Hi Peter,
Perhaps I'm not running my tests the correct way. Here are the steps that I went through:
1. Run VI and keep run# as 100
2. Click on 'Load' button and specify a random file for the Sequence File
3. Click on 'Start' button
4. After a few seconds, click on 'Stop' button
5. Click on 'Report' button
6. Click on 'Exit' button
The Result shows me the file I selected in step 2.
I repeated the above steps except changed the run# to 101 and picked a different random file. And both times, the Result array displayed the file I had selected in step 2 above. Is this not correct? Please let me know if I'm doing something wrong. I ran the tests with the new data that you sent to me. Also, can you elaborate on what you meant by "the first event timestamp was before the beginning of the run" in terms of your specific application?
Thanks!
A.S.
Anu Saha
Academic Product Marketing Engineer
