12-12-2012 02:33 AM
Can I check or uncheck view as icon property of multiple block diagram objects at once??
Solved! Go to Solution.
12-12-2012 02:57 AM
If you've tried to, you will already know the answer.
Or there is a setting in Tools - Options - Block Diagram to 'place front panel terminals as icons' if that's what you are looking for.
12-12-2012 03:10 AM - edited 12-12-2012 03:10 AM
Yes, In LabVIEW 2012 you can select any number of terminals, right-click, and change them all at once.
(In LabVIEW 2011 and earlier you cannot do that)
