11-08-2012 02:23 PM
The device is NI PXI-1010, I can ping the device but I cannot connect it through MAX. I am using version 4.5. Whenever I try to set up a new remote system, it cannot find the remote device. I have tried using both the computer name (which is resolved to an IP address in the hosts file) and the just IP address. I get this error: "Unable to initialize connection to remote system(s)."
I am able to ping the remote computer and but I cannot browse to it in Windows Explorer.
11-08-2012 02:29 PM
The PXI-1010 is just a chassis. What controller are you using? How is it configured? What OS does it have?
If you have a Windows controller, then you probably need to setup sharing, domains, and other network settings.
11-08-2012 02:50 PM
OK, I am using the XP in both computer, what I need to set? And I am a beginner, Please tell me more details. Thank you.
11-08-2012 07:35 PM
The first thing I would check would be the workgroups. If the workgroups are not the same, Windows will make it very difficult to communicate with each other.
11-09-2012 04:51 PM
I cannot make them in the same group and I have tried to do that and Max are still unable to find the PXI. FYI, the PXI is 8187.
11-12-2012 03:37 PM
So far,I reinstalled the OS and I can see the chassis on NImax. But why I cannot find device? Do I need some driver?
