11-20-2014 02:58 AM
I have MyRio and LabView 2014 with all the modules installed and updated.
Xilinx 2014 is also installed and I can compile for FPGA.
However in block diagram I can't find HDL interface Node for importing VHDL code. As you see in the second screenshot.
How may I solve this issue?
11-20-2014 07:10 AM
Try searching for it by clicking on the search button on the functions pallete or by pressing control+spacebar. You can also change your visible palletes to all and browse that way. Good luck.
11-20-2014 07:26 AM
You mean that IP Integration node?
11-21-2014 04:23 PM
I can find IP integration node. However I'm looking for HDL Interface Node as it is mentioned in the following whitepaper:
http://www.ni.com/white-paper/3483/en/
I think the functionalities are the same. Maybe NI has replaced the HDL interface Node with IP Integration Node?
02-21-2015 11:03 AM
me too need the answer....
02-24-2015 10:24 AM
Did you find HDL interface node?
02-24-2015 04:41 PM
The is no IP integration node in LabView 2014. Instead use HDL Interface Node.
Yes I did use HDL Interface Node and it worked great.
05-21-2018 09:35 AM - edited 05-21-2018 09:41 AM
I know this thread is really old but just to help clear things up from aan928's confusing solution for anyone else who comes across this forum post:
The HDL Interface Node was replaced with the IP Integration Node beginning with the LabVIEW 2010 FPGA Module.
