03-31-2015 03:42 AM
Hi! There is the problem that I am facing now, is the connection that says,
You have connected two terminals of different types.
The type of the source is cluster of 2 elements.
The type of the sink is 1D array of
double [64-bit real (~15 digit precision)]
how to figure this out and may I have the solution, please?
Aloysius Low
03-31-2015 04:02 AM - edited 03-31-2015 04:07 AM
If you look at the context or detailed help for the graph, it explains the data types that it accepts. The waveform graph is used for displaying a complete set of time-series data with a uniform time between points. (with a t0, dT and Y values). It accepts either a 1D or 2D array of points (where t0 = 0 and dT = 1) or a waveform.
You are probably looking for an XY graph instead of a waveform graph - that is used to display an arbitrary plot of X & Y values and accepts a cluster containing an array of X and Y values.
03-31-2015 04:03 AM
I cant open your vi as I only have 2012 on this machine. A snippet would be useful.
However, the error message explains everything 🙂
Looks like you are trying to feed a cluster of two elements into a graph that is expecting a 1D array of numbers. Where do you get your cluster from, and what are the two elements in it? Normally you would have an array of data to feed into a graph (feeding in just one point kind of defeats the object of having a graph) so why do you have a cluster rather than an array?
03-31-2015 05:45 AM - edited 03-31-2015 05:45 AM
You need to wire it to a XY graph the way it is programmed in your VI. The first array contains the X values and the second array contains the Y values.
Now, if it's not what you want, you can still use a waveform graph but instead of using the bundle cluster use the build array, but this will create two waveforms. See examples below:
03-31-2015 07:43 PM
Thank you for the solutions.
