I receive the following error message when I try and compile my project to an executable:
Error 1003 occurred at ABAPI Dist Chg and Save VIs.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: The VI is not executable.
I can compile other VIs and some of the examples without any issues.
Sometimes my main VI is not executable and other times it is executable.
When it is broken, the error indicates that there is an unwired terminal in a sub VI. When I inspect the trouble causing VI, there are no unwired terminals or broken wires.
It seems to be an issue with ActiveX and using an Invoke Node to open an Excel Workbook.
In order to return it to working order, I need to delete and recreate and rewire the Invoke Node in the sub VI and all is well again. I can run everything in LabView itself, but when I try and create an executable, I encounter problems every time.
