01-14-2008 08:33 AM
01-15-2008 02:58 AM
hi there
this is fun: clean installation of LV 8.5 on a clean system, but still can't add any "Additional Installer" Thanks a lot....
01-15-2008 04:55 AM
now i installed the previous release of LV8.5 (Q2 instead of Q3 on the same machine). and guess what: now it works (see attachment)! 3 days of work!! brilliant.
01-15-2008 11:05 AM
01-15-2008 11:18 AM
Hello Bop
"If you still have that clean machine set up ..."
i had to hurry up a bit to create the installer today, so i re-installed the Q2 distribution to my development system this afternoon. but a colleague of mine is showing up tomorrow, he also has a Q3 distribution, so i can do this test.
"Besides LabVIEW 8.5, was there anything else required..."
The app works just as a OPC client application, so i just installed plain LV 8.5 without device drivers, toolkits, modules or 3rd party etc.
"I'm unfamiliar with the Q3 label you mentioned..."
we use the devolper suite. Since 2007 the DVDs are labelled as "Third Quarter 2007" etc. instead of "August 2007". The LV .- Version has not changed between the two distributions (const. 8.5), and no device drivers, toolkits or modules has been used (but they have been installed on my original Q3 development system !).
I hope to have some logfiles tommorrow afternoon.
01-16-2008 10:36 AM
Hello Bop
no problems on my colleagues Q3 system. So i reinstalled the Q3 on my development system, and now it works there also!
maybe the problem was the upgrade of the source/project files from 8.20 to 8.50, and not the development system, but i don't want to try to reproduce the error#
Sorry, no files for you! If something similar happens with one of our other projects i'll append to this post.
Thanks anyway
01-17-2008 02:03 PM
11-12-2008 08:22 PM
Same problem, different scenario.
I also get the disabled "Other installers" panel and the installer is not created (nothing happens really) and I only get the same error message posted before.
I modified the .ini file to get a log of this (attached).
OK, now the scenario. LV version 8.6 (Third Quarter 2008). The project was created from scratch on this version and it DID work before. It is not "project" specific because I opened an older project (also 8.6, created in the same machine) and I got the same problem.
Thanks for any ideas!!
/El Gus
