USB interface VISA RAW comunication with a HID device
Well I'm with same problem. I've made the .INF file and when I try comunicate with LV or MAX, this error BFFF003A appear... 😞
It's curious because on the IDE that I do the program to uC there is a tool that communicate with hardware normally. In fact, that tool just communicate when I don`t use the .INF file create by MAX and yes when I use the HID Driver Windows default.
MAX recognize the device, but when I try send and receive Bytes the error comes.
Please Help...
Angelo
Message 11 of 13
(1,943 Views)
Hello
  I am using NI USB VISA to communicate with segger USB device .HID Generic RAW USB detected in NI MAX.while Reading i am getting an error  "(Hex 0xBFFF003A) unable to start operation because setup is invalid due to attributes being set to an inconsistant state.pls help me to sort out this error.error screen shots are attached.
Message 12 of 13
(900 Views)
hello,
Is your problem solved? I encountered the same problem, you can share the solution?
Message 13 of 13
(837 Views)
