02-21-2013 08:48 PM
Hi
This is the situation. I run a LabView program that reads in PT 100 elements and controls 1 DAQ card. I also like to communicate in the same programme with a different device over a USB cable. The communication with this device is established by calling a dll file in the system 32 file. Everything works correct for 1 minutes and than it closes all the communication the all the USB ports, also the one that is connected with the DAQ card. If I pull out and connect the USB to the device again everything works again except the DAQ card.
Is there someone who can help me with this?
Thanks for the effort
02-22-2013 02:07 PM
Sounds like something could be happening with the refernces to your USB ports. Have you tried isolating the issue to a particular part of your code? Specifically, the dll calls? I.E. If you remove or diagram disable all code having to do with the dll and call library function nodes, then does this behavior still occur?
--Ryan S.
02-23-2013 06:46 AM
Hi Ryan
Thanks for the answer. I made a VI just like the one in the main vi I have to test the communication with the device. Here the USB port also stops communicating. So it gives the same result.
It must go wrong somewhere in the while loop. It is working OK for a few seconds and than just stops.
In attachment is the Vi. Do you see something wrong with it?
I also attached the main program where I do almost the same
--Ryan S.
Thanks for the help and the effort
Greets
Vincent
02-26-2013 09:30 AM
Hello Vincent,
Can you give some more information about the DAQ device and the DLL/Driver you're using?
Thanks!
02-27-2013 07:31 AM
Hi ThiCop
Thanks for the answer and the effort!!!!
It is a NI-DAQmx who is generating 2 times a -10 to 10 V signal to 2 valves who controls temperature and flow in the process. The other device is a Testotherm 330 to measure exhaust gases from boilers. These drivers and all the dll files are delivered by testotherm itself. If I install the USB driver and install the DLL files and use the online reader that is supplied by Thestotherm everything works good. When I run it in LabView it breaks the communication after a few seconds.
Thanks for helping me solve this problem. Really appreciate the effort.
Greets
Vincent
03-01-2013 04:02 AM
Hello Vincent,
From where did you download the drivers?
Are these licensed or freely available?
03-01-2013 05:19 AM
Hi ThiCop
The driver is free available on the website of Testotherm. You find them under the testo 330 downloads
The dll files I received from the German helpdesk. I can share these with you over dropbox if you like?
The driver is working correctly if I use the onlinereader that is provided by Testo. But when connected to LabView it works only for a short time. To call the correct functions in the dll file I just used the VAB code they use when you log all the measured data in an excel sheet.
Hope this is a littlebit clear.
Thanks again for thinking with me!!!
Greets
Vincent
03-01-2013 05:24 AM
Hello Vincent,
Just to be 100% sure.
The "helpdesk" you're talking about is the Testo helpdesk, right?
03-02-2013 07:31 AM
Hi ThiCop
Indeed the Testo helpdesk.
In attachment is the excel we used to build up the LabView program.
Thanks!!!!
I hope we find the solution!!!
03-05-2013 04:57 AM
Hello Vincent,
Did they give you any "guidelines" on how they expect you to call the functions?
Do you have any extended documentation on the DLL itself and how they expect you to call it?
I must admit that it has been a while since I've used Excel macro's.
At first glance I think most issues would be caused through the implementation of the timer.
Can you share the latest version of your code (that contains all needed subVI's)?
This way I can start from that.
