10-25-2007 07:33 AM
I have a problem with the drivers when I am using the device USB-6501. I need to get a program, where I can configure some ports as inputs, others as outputs and one of them as a counter. I have found two very useful examples. One is the ‘Count digital events’ that appears on the list of examples and the other one is ‘USB 6501 Interactive Control’. However, to use the first one I need to have installed NI-DAQmx whereas to use the second one I need NI-DAQmx Base. I can switch between them but the problem is that I can only run one of the programs each time. I would like to put everything together in another program, but how can I do it?
I would appreciate any suggestion. Thanks in advance
Vicente
10-25-2007 07:43 AM
10-25-2007 08:50 AM
Hi Dennis,
Many thanks for the suggestion, but I have tried to do it now and I have realized that some fields of some Sub-VIs don't match exactly. I can't run the program at the moment. Is it possible to find one of these examples using the other drivers? I mean 'USB 6501 Interactive Control' with NI-DAQmx or the events counter with NI-DAQmx Base.
Best wishes
Vicente
10-25-2007 09:17 AM - edited 10-25-2007 09:17 AM
It is simply not true that the fields for some of the subVIs don't match exactly. Here's the subVI. It took me about one minute to do this. I also don't understand why you don't simply use one of the shipping examples I mentioned.
Message Edited by Dennis Knutson on 10-25-2007 08:18 AM
10-25-2007 10:17 AM
Sorry, but I can’t open your Sub-VI because it’s a newer version, can you save it again in version 8.0, please? I tried to do what you told me but I attach you what I got. I can’t wire the array to the ‘Writing Function’ and why isn’t your error in in pink?
Many thanks
Vicente
10-25-2007 10:27 AM
07-10-2009 03:43 AM
Hey,
I need the SubVI 6501.UpdateDIO.vi for the LabVIEW-Version 7.1. Does anybody have it and can post it?
thanks
liku
