USB 6009 DAQ to use in Simulink at External mode with DAQ toolbox
hi
Currently I am using usb 6009 daq board for data acquisition in using simulink. I have created a model with taking analog input from data acquisition toolbox. Then when i want to run in external mode and try to connet to target, the following error is coming up:
Could not execute target data map file 'untitled_rtwin_win32\untitled_targ_data_map' or it does not exist. Stop the target, delete the untitled executable, rebuild the code,and try again. Note that execution of external mode requires the build directory to be present...
How can I solve this problem? For your info, I am using 32-bit matlab, version: 2012a
For your info, a snapshot of the error is attached,
Any help would be appreciated Thanks
(3,101 Views)
Hi Mahmudur,
what does MathWorks say about this error message?
(3,091 Views)
Hi GerdW,
I haven't receieved any response from mathworks yet..do you have any idea?
thanks
(3,074 Views)
How to get the Ni6009 toolbox in matlab.?
I dint get the block in my matlab.
(2,717 Views)
