03-22-2007 09:00 AM
Hi all,
Firstly apologies if this question has been answered/posted before and also
apologies if it seems rather trivial.
I’m an amateur at things like this!
Anyway I'm using Labview 7 express and USB - 6009.
I quite simply want to record and view a voltage signal and a current signal.
Thanks for all your help and hopefully I've made myself clear in what I want to
find out.
Andrew
03-26-2007 07:39 AM
Hi Andrew
Do you want to post your code on this thread and that way I can see what kind of setup you are dealing with, what you would liek to do seems straight-forward so should work.
Kindest Regards
YatinM
07-13-2007 02:09 AM
Hi all,
Firstly apologies if this question has been posted before and also
I’m an amateur also at things like this!
Anyway I want to use Labview 7 express with USB - 6009 / USB 6210.
i have LV 7 Express along with MAX 3.5 , where as i m using NI PCI XXXX with this software configeration n providing solutions to different end use there fore not able to change the plateform. i recentely got the USB 6009 ( qty = 2 ) and USB 6210 ( qty = 1 ) along with the drivers CDs but these drivers r for LV 7.1 or above version.Thus plz help me by providing the right drivers for the LV 7 express with MAX 3.5
find out.
